MauriASR Posted January 4, 2016 Posted January 4, 2016 Hi guys, I have a problem with destiny practically with the strict off I do a few games in pvp is then becomes impossible error beaver continuously!!! Can someone help me? Thank you all
Tommy885 Posted January 4, 2016 Posted January 4, 2016 Hi there, Make sure you have auto cloud and Bleeding edge cloud enabled in Miscellaneous Settings. - Tom
MauriASR Posted January 4, 2016 Author Posted January 4, 2016 Hello Tom, they are enabled,then I enabled UPNP, you have some setting recommend? Or I have to open some ports Tnx
Administrators Netduma Fraser Posted January 5, 2016 Administrators Posted January 5, 2016 If they are both enabled you should be okay and no need to manually port forward. If the above are both enabled is there anything coming up as blocked on the Geo-filter?
MauriASR Posted January 6, 2016 Author Posted January 6, 2016 Tnx, i'm sorry but i did't understand your question. Anyway, yesterday i try to amplify geo filter radius ( from 800 to 1300 km ) and i activate ping assist ( from 0to40) and i play some very good game, i had beaver error just one time.
Administrators Netduma Fraser Posted January 6, 2016 Administrators Posted January 6, 2016 Tnx, i'm sorry but i did't understand your question. Anyway, yesterday i try to amplify geo filter radius ( from 800 to 1300 km ) and i activate ping assist ( from 0to40) and i play some very good game, i had beaver error just one time. Great to hear. We usually recommend at least ~1000km. My question was when you get the beaver error with strict mode off is there a caution triangle that appears on the map?
