Usb destroy Posted November 19, 2015 Posted November 19, 2015 salut a tous je vous explique mon probleme je regle mon filtre sur 1200km a 42ping assit ,je tombe toujours sur des parties merdique!! le routeur me dit un ping pas trop mal entre 25 40 de ping mais en jeux c different je passe du vert au jaune decalage ect, si quelqu un peut m aider merci
Lo0uiz Posted November 19, 2015 Posted November 19, 2015 salut, En survolant le forum, il faut mettre ping assist à 0, mode strict activer et réduire ton radius entre 500 et 1000 pour blops3. Apres faut dire la co est degueu sur ce jeu ces derniers jours.
Netduma Staff Netduma Crossy Posted November 19, 2015 Netduma Staff Posted November 19, 2015 Seriez-vous en mesure d'afficher les informations à partir d'ici s'il vous plaît http://wiki.netduma.com/doku.php?id=lag_support_instructions
Usb destroy Posted November 19, 2015 Author Posted November 19, 2015 PingPING 8.8.8.8 (8.8.8.8): 56 data bytes64 bytes from 8.8.8.8: seq=0 ttl=40 time=32.518 ms64 bytes from 8.8.8.8: seq=1 ttl=40 time=32.566 ms64 bytes from 8.8.8.8: seq=2 ttl=40 time=33.577 ms64 bytes from 8.8.8.8: seq=3 ttl=40 time=32.173 ms64 bytes from 8.8.8.8: seq=4 ttl=40 time=33.230 ms64 bytes from 8.8.8.8: seq=5 ttl=40 time=32.592 ms64 bytes from 8.8.8.8: seq=6 ttl=40 time=32.898 ms64 bytes from 8.8.8.8: seq=7 ttl=40 time=31.919 ms64 bytes from 8.8.8.8: seq=8 ttl=40 time=32.570 ms64 bytes from 8.8.8.8: seq=9 ttl=40 time=32.655 ms64 bytes from 8.8.8.8: seq=10 ttl=40 time=32.456 ms64 bytes from 8.8.8.8: seq=11 ttl=40 time=36.267 ms64 bytes from 8.8.8.8: seq=12 ttl=40 time=32.842 ms64 bytes from 8.8.8.8: seq=13 ttl=40 time=32.545 ms64 bytes from 8.8.8.8: seq=14 ttl=40 time=32.991 ms64 bytes from 8.8.8.8: seq=15 ttl=40 time=32.799 ms64 bytes from 8.8.8.8: seq=16 ttl=40 time=32.392 ms64 bytes from 8.8.8.8: seq=17 ttl=40 time=33.233 ms64 bytes from 8.8.8.8: seq=18 ttl=40 time=33.002 ms64 bytes from 8.8.8.8: seq=19 ttl=40 time=32.136 ms--- 8.8.8.8 ping statistics ---20 packets transmitted, 20 packets received, 0% packet lossround-trip min/avg/max = 31.919/32.868/36.267 ms Tracetraceroute to 8.8.8.8 (8.8.8.8), 30 hops max, 38 byte packets1 192.168.1.1 0.379 ms 0.292 ms 0.273 ms2 77.144.48.1 21.359 ms 22.342 ms 22.122 ms3 86.65.74.149 21.930 ms 21.522 ms 21.148 ms4 84.96.163.154 22.227 ms 22.530 ms 21.917 ms5 109.6.8.205 22.472 ms 22.604 ms 22.171 ms6 109.6.15.13 22.468 ms 23.795 ms 22.665 ms7 84.96.163.162 24.174 ms 24.109 ms 23.333 ms8 * * *9 72.14.238.234 26.817 ms 45.757 ms 26.581 ms10 209.85.248.21 28.004 ms 209.85.248.31 30.449 ms 209.85.245.72 27.285 ms11 216.239.51.196 33.349 ms 216.239.51.110 31.693 ms 31.910 ms12 216.239.51.149 32.413 ms 209.85.250.165 33.156 ms 209.85.248.101 33.667 ms13 * * *14 8.8.8.8 34.694 ms 40.817 ms 36.086 ms Online Gaming Services
Usb destroy Posted November 19, 2015 Author Posted November 19, 2015 Se Host Filtering.html Host Filtering.html Internet Diagnosis.html
Chive972 Posted November 20, 2015 Posted November 20, 2015 Salut Usb Destroy, Je vais animer une session d'aide ce soir via Skype. Si ca t'intéresse, n'hésite pas à m'ajouter sur Skype. Mon pseudo est le même.
Usb destroy Posted November 20, 2015 Author Posted November 20, 2015 salut ok vers qu elle heure stp?
Chive972 Posted November 20, 2015 Posted November 20, 2015 J'essaye d'être présent de 19h à 21h. Envoie moi un message quand c'est bon pour toi.
tentrum Posted November 24, 2015 Posted November 24, 2015 Mon strict mode est activer et le ping assist est réglé sur 50ms, le netduma me donne toujours des parties a l'intérieur de mon geofilter ou dans 80% des parties dans le serveur dédié du Kansas qui est en dehors de mon geofilter mais sous les 50ms. Je comprends que le mode strict donne droit au serveur dédié hors geofilter si le ping du serveur est sous le ping assist demander. Mais personnellement le serveur dédié ce n'est pas vraiment bon. J'aurais aimé qu'il y ait un mode qui ne permettent rien rien rien en dehors du geofilter peux importe le ping que je choisis.
Usb destroy Posted November 24, 2015 Author Posted November 24, 2015 salut essaye de mettre de ping ass a 0 moi c pareil quand je regle le ping sur 50 je me retrouve sur un serveur dediee au usa ou meme un hote americain avec 50 de ping en jeux bizarre
tentrum Posted November 24, 2015 Posted November 24, 2015 quand je met le ping assist a zéro cela est parfait quand on est seul. mais quand on est party leader de 3 ou 4 personne c'est vraiment difficile. a BO3 .Meme si j'ai mis toute mes amis dans la liste ALLOWS il manque toujours quelqu'un dans le lancement de game. Ou je tombe en mode local et je dois redemarrer le jeux finalement le monde finissent par me dire de le fermer sinon on jouera pas ce soir. Ce qui fait que je m'en sert que pour voir que je ne me connecte pas plus loin que le kansas.
Chive972 Posted December 4, 2015 Posted December 4, 2015 tentrum, si tu as encore des problèmes nous pouvons voir ensemble mais tu dois d'abord créer ton propre topic. Je clos celui-ci.
