scooby Posted October 24, 2015 Share Posted October 24, 2015 Ok guys so i have got internet connection..XB1 working..but network monitor only showing my wireless laptop..nothing else Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted October 24, 2015 Netduma Staff Share Posted October 24, 2015 Hi Scooby, Do the other devices show at the top of the Network monitor? Link to comment Share on other sites More sharing options...
scooby Posted October 24, 2015 Author Share Posted October 24, 2015 No Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted October 24, 2015 Netduma Staff Share Posted October 24, 2015 No If you go to the device manger to the devices show in there? Link to comment Share on other sites More sharing options...
scooby Posted October 24, 2015 Author Share Posted October 24, 2015 They show in the dhcp lease Link to comment Share on other sites More sharing options...
scooby Posted October 24, 2015 Author Share Posted October 24, 2015 Not on device manager Link to comment Share on other sites More sharing options...
scooby Posted October 24, 2015 Author Share Posted October 24, 2015 Just laptop Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted October 24, 2015 Netduma Staff Share Posted October 24, 2015 Can you check to make sure your other devices are definitely connected to the Netduma and that they have't connected to your old routers Wifi or something like that. If they are can you reboot the Netduma and see if they appear. Do any 'nameless' devices appear? Link to comment Share on other sites More sharing options...
scooby Posted October 24, 2015 Author Share Posted October 24, 2015 They r definitely connected..all show in dhcp lease..there r a lot of unknown devices but that was the case on my old router Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted October 24, 2015 Netduma Staff Share Posted October 24, 2015 They r definitely connected..all show in dhcp lease..there r a lot of unknown devices but that was the case on my old router The unknown devices are probably then Xbox and other devices. If you go to device manager and click edit at the top you can change the names of the unnamed devices to their actual names. You can match them up by using the IP Address that is shown. Link to comment Share on other sites More sharing options...
scooby Posted October 24, 2015 Author Share Posted October 24, 2015 They are not showing in device manager just my wireless laptop.i can only see all my connected devices by looking at dhcp lease Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted October 24, 2015 Netduma Staff Share Posted October 24, 2015 They are not showing in device manager just my wireless laptop.i can only see all my connected devices by looking at dhcp lease Oh, I see what you mean. Can you make sure that you are using Google Chrome to access the interface Link to comment Share on other sites More sharing options...
scooby Posted October 24, 2015 Author Share Posted October 24, 2015 Ok..not using chrome..just tried on my phone and they r showing..will download chrome and try..thx for your help im sure this wont be my last post Link to comment Share on other sites More sharing options...
Netduma Staff Netduma Crossy Posted October 24, 2015 Netduma Staff Share Posted October 24, 2015 Ok..not using chrome..just tried on my phone and they r showing..will download chrome and try..thx for your help im sure this wont be my last post No worries Post back with how you get on and if you need any more help. Link to comment Share on other sites More sharing options...
