vincho31 Posted January 30, 2015 Posted January 30, 2015 Hi, first of all , sorry for my poor english ....i'm french I got my R1 yesterday & updated it to version 1.02.6. Here attached my finalized installation All systems are working properly (tested the PS4 with my "new" connection , it's amazing! ( i'm now a PGM on Advanced warfare ) I have just un issue with my TV (IPTV by ADSL ) I have the internet signal at the DLAN outlet (tested with cable wired to my laptop ). but it seems i didn't receive the TV flow (signal). Main TV menu is displayed but channels don't work.... For information: - i had to put my R1 in DMZ to get open NAT on my PS4, this is the only setting i did on my installation - When my IPTV box is plugged on my ISP ethernet port , my TV is working properly. Did i miss something to set in the router ? .Thank you in advance for the interest you'll have to my topic. Olivier schema.tiff
Guest Netduma_Iain Posted January 30, 2015 Posted January 30, 2015 Hi Vincho, Thanks for purchasing, glad you're enjoying the router I recommend plugging iptv into the other router. Its probably designed to only work with the other router.
vincho31 Posted January 30, 2015 Author Posted January 30, 2015 Hi, thks for you prompt reply, this is indeed what i've read on the manufacturer forum ... so , i can't control the bandwidth allowed to the ISP through the Duma.... too bad Olivier
Guest Netduma_Iain Posted January 30, 2015 Posted January 30, 2015 Erm yeah I'm not sure, the ISP probably has dedicated space for the TV you know. So not such a big deal I don't think.
vincho31 Posted January 30, 2015 Author Posted January 30, 2015 no doubt thank anyway for your interest
