Destiny settings help
Hi i've been following the destiny settings on the wiki but every time I disable auto ping host and enable peer ping the changes end up reverting back to the latter as if they are not saving. is this normal ?
If you go to settings > miscellaneous and click enable cookies that will save your settings normally. However a factory reset will wipe all your settings as it returns it to the state before you input any settings at all.
Since this issue seems to be solved I will close this thread. If you have any other issues please don't hesitate in reposting and Happy gaming.
