Wireless issue (on android)
When my phone is on the netduma wireless sometimes, after a while, it will say it's connected to the netduma wireless ALTHOUGH I can't access the internet and i have to restart my phone to regain wireless access to my netduma. This is an issue, i don't have when i use my bt home hub wireless.
Can you go to Settings >> Miscellaneous and untick Wifi work around and see if that resolves the problem :)
Don't see that option in miscellaneous bud
It's not a huge issue but when i leave my phone on over night i have to remember to switch it to my bt home hub wireless
seems to have worked thanks.
Do you know how i can change my IP encase i get ddos'd? do i need to do it through my netduma or my bt hub?
Do that through your BT hub. You should be able to just unplug it for a few minutes and then plug it back in and it should change :) As your original problem is solved, I'll close this thread, but if you have anymore questions please feel free to open a new one :)
