abc123 Posted January 26, 2015 Posted January 26, 2015 TITLE says it all.... basically if I download anything at ~max download the TX Rate of the Wifi drops to 7Mbs
Guest Netduma_Iain Posted January 27, 2015 Posted January 27, 2015 Ok mate let me get .7 fixed then we'll address it. As a precaution can you try disabling IPv6 on LAN/WAN and misc linklock IPv6 as well please and try again.
abc123 Posted January 27, 2015 Author Posted January 27, 2015 still happening...whole network crashes about 9 times a night... can't take it much more so removing the R1 from my network for the time being, i'll likely put it at the end of the tunnel...
Guest Netduma_Iain Posted January 27, 2015 Posted January 27, 2015 Has this only just started happening abc?
abc123 Posted January 27, 2015 Author Posted January 27, 2015 Has this only just started happening abc? nope, but i've been downloading TV shows the past week and this high utilization causes the complete network shutdown. I've removed the R1 from my network 100% now. I'm still downloading and have yet to run into the issue that would of happened 3 times by now.
Guest Netduma_Iain Posted January 27, 2015 Posted January 27, 2015 Ok I'll look into it, can you use the wifi on the other device in the meantime please.
abc123 Posted January 27, 2015 Author Posted January 27, 2015 I am, I likely won't plug the R1 back in...if i do it will purely be to use on the xboxes under the WRT1900AC, can't deal with my wife asking me questions about our network anymore. She doesn't comprehend the issue and doesn't know why I can't solve it...I can't try to explain it to her anymore, at the end of the rope before she stabs me
Guest Netduma_Iain Posted January 27, 2015 Posted January 27, 2015 ahh I see, will look into very soon.
abc123 Posted January 27, 2015 Author Posted January 27, 2015 no worries, i think this is the lilstone issue to be honest. It only happens when i'm using full bandwidth for extended periods of time... Wifi will drop out fail, modem fails out... rebooting modem solves...but my wife notices when i flash openwrt updates...(she's always on the internet)
Guest Netduma_Iain Posted January 27, 2015 Posted January 27, 2015 ok sure its a top priority after I sort out this bugs with PA in .7
abc123 Posted January 27, 2015 Author Posted January 27, 2015 no worries, I completely understand that the need of the many outweighs the needs of the few. Not ever user has this problem because they don't over utilize their network like i do daily.
