My installation
Guest Netduma_Iain
Yes UPnP should be enabled on the duma. Can you take a screenshot of the "Settings > UPnP" page please :)
Guest Netduma_Iain
When you turn on your console do you more entries getting added in that table? You should do.
Guest Netduma_Iain
Ok I think i know what the issue is have you done this?
Wall > Modem > R1 > Other Router > Game console
If so I'd recommend if you can connect the game console directly to the R1 not through another router
Guest Netduma_Iain
Whats strange is that the UPnP table is not filling up, has it still not changed when you start the game? Have you set a static IP on the console I'd recommend you choose dynamic/auto please.
