Losing Ethernet connection - But Wifi is ok
Hi,
I am losing internet connection, on wired equipment by ethernet on 2 computers and 2 consoles (PS4 Pro and Xbox One X).
However I still have Wi-Fi as my Phone and Printer still works.
The only way I can get ethernet connection back is rebooting the XR500.
This has happened multi times, over the last 5 days, a friend also with the same router has had this issue.
This is also happening multi times per day.
I have the latest Firmware for the XR500
I am using Virgin Meida Cable connection, which I have done for a long time.
Here is the Log I got from Settings -> Monitoring > Logs before rebooting:
[admin login] from source 192.168.1.3, Saturday, April 07, 2018 11:09:53
[DoS Attack: SYN/ACK Scan] from source: 52.187.128.177, port 80, Saturday, April 07, 2018 11:06:33
[DoS Attack: SYN/ACK Scan] from source: 35.227.211.192, port 80, Saturday, April 07, 2018 11:05:08
[DoS Attack: SYN/ACK Scan] from source: 35.227.211.192, port 80, Saturday, April 07, 2018 11:04:52
[DoS Attack: SYN/ACK Scan] from source: 35.227.211.192, port 80, Saturday, April 07, 2018 11:04:44
[DoS Attack: SYN/ACK Scan] from source: 35.227.211.192, port 80, Saturday, April 07, 2018 11:04:40
[DoS Attack: SYN/ACK Scan] from source: 35.227.211.192, port 80, Saturday, April 07, 2018 11:04:38
[DoS Attack: SYN/ACK Scan] from source: 35.227.211.192, port 80, Saturday, April 07, 2018 11:04:37
[DoS Attack: SYN/ACK Scan] from source: 220.181.57.216, port 80, Saturday, April 07, 2018 10:36:47
[DoS Attack: SYN/ACK Scan] from source: 37.187.158.175, port 40282, Saturday, April 07, 2018 10:35:33
[DoS Attack: SYN/ACK Scan] from source: 37.187.158.175, port 40282, Saturday, April 07, 2018 10:34:50
[uPnP set event: add_nat_rule] from source 192.168.1.2, Saturday, April 07, 2018 10:01:42
[DumaOS] DHCP new lease allocated., Saturday, April 07, 2018 10:01:41
[DumaOS] DHCP new event., Saturday, April 07, 2018 10:01:41
[DHCP IP: 192.168.1.3] to MAC address 4c:66:41:94:15:e1, Saturday, April 07, 2018 10:01:41
[uPnP set event: del_nat_rule] from source 192.168.1.254, Saturday, April 07, 2018 10:01:11
[DoS Attack: SYN/ACK Scan] from source: 220.181.57.216, port 80, Saturday, April 07, 2018 09:14:03
[DoS Attack: SYN/ACK Scan] from source: 220.181.57.216, port 80, Saturday, April 07, 2018 09:10:20
[DoS Attack: ACK Scan] from source: 177.93.106.27, port 36004, Saturday, April 07, 2018 08:53:26
[DoS Attack: SYN/ACK Scan] from source: 220.181.57.216, port 80, Saturday, April 07, 2018 08:52:11
[DoS Attack: SYN/ACK Scan] from source: 220.181.57.216, port 80, Saturday, April 07, 2018 08:43:29
[Time synchronized with NTP server] Saturday, April 07, 2018 08:33:58
[DoS Attack: ACK Scan] from source: 177.93.106.27, port 36004, Saturday, April 07, 2018 08:32:01
[DoS Attack: SYN/ACK Scan] from source: 90.195.172.154, port 80, Saturday, April 07, 2018 08:30:57
[Log Cleared] Saturday, April 07, 2018 08:26:37
Thanks
View the full article
