Slower Speed on Ethernet
I just installed the router and have noticed a problem. When running speed test from my wired PC, the speed is around 30 download. I currently have 100 from spectrum. Before switching the router out it was over 100, and now not close. Have reset the modem, have reset the router, have cleared my dns and arp cache on the pc. If i do a speed test on my phone, it comes up and shows 110, like it should. So not sure why the ethernet connection is slower.
View the full article
I think it makes sense in checking of your router connection. I found one useful guide as for me with the detailed instructions. It will help you adjust settings on your modem or Wi-Fi router by using its IP address – 192.168.1.1 . Hope it helps.
