BT smart hub
BENORMOUS
I'm a bt infinity customer from Wednesday onwards and can't wait as I've not even tried the new cods yet but what I'm wanting to know is if any of you guys have the new bt smart hub,does it play nice with the duma?anything I need to know before I try gaming?I'm sure I can figure out how to put duma into dmz so that's an obvious easy one but if any of you have come across problems with it and sorted them then I'd be thankful
I have one the only issue i get with the BT Smart Hub is it likes to Restart itself every 14 Days This is a ISP issue that's built in to the Smart Hub Firmware the only way to stop this is if you get your own modem im still stuck with this BT Smart Hub it's ok it will do for the majority of users. like myself mines connected up to the netduma and is in dmz mode and works well with it. :)
Well I have an openreach modem I could put in 1st place before anything,think I'll just try the smart hub first,every 2 weeks isn't too bad I don't think,don't think it will cause a dlm upset with that kind of gap between the resets,thanks for the heads up mate
