Sony Vegas Settings Part 2
RADDY1993
5) now its time to render your video, so open the render templates and select the ones shown below.
6) Now copy all the render settings below.
7) now just select where to save your rendered video and hit RENDER.
Hope these settings help a few of you out and make your videos look a bit better.
VIDEO RENDERED USING THESE SETTINGS
https://www.youtube.com/watch?v=GnylOzQl4Xw&feature=youtu.be
WATCH IN HD
as a suggestion id render in 1440p or 4k to youtube despite the source being 720p or 1080p
that way you get a higher bitratio which makes the video look better
in addition to that video effects like sharpening do make a huge difference in quality after youtube processed the video, its not only the rendering settings that influence the youtube quality
also while youtube prefers mp4 i get way better results when rendering in wmv
most of my videos in 480p look way better than other peoples 720p videos
edit: your video is set to private
what are your rendering settings?
Yes i have tried all those ways you talk about but they take hours to render and upload, my way renders a 10 min video in around 30 mins with not bad quality. The video is on public now so take a look :).
btw i saw you covered the video effects in tutorial 1, forget about what i said with sharpness and stuff then :)
Seems you are an expert RADDY . nice post.
Here is something I want you to help me with.
When something cool happens (collateral kills for example), I want to zoom in kill feed while the video runs. How can I do that?
thx
