Network Monitor not working as intended
hey guys
got an issue, my upload monitor is not working as it should
im currently uploading a video to youtube as you can see in the picture, however the network monitor doesnt showcase that
the bandwidth is correctly set and the youtube video is also uploading at max upload (you can tell by the percentage it increases)
congestion control has share excess ticked
the small R1 browser window is the active one (this matters to have the network monitor show correct results)
any ideas?
coal mine firmware btw
Guest Netduma_Iain
The odds of that being broken is quite slim. As its been tested for a very long time.  Have you got anti-flood set to a low value?
no it was set to 100% to be sure i have all of my upload available
the odd thing is its fully working now again for both up- and download rates in the monitor
id say its solved for the first but ill keep an eye on it :)
Guest Netduma_Iain
Ok thanks man.
Traffic usually goes in saw tooth pattern so you'll see the bar go to 100% then down to 0% then repeat. But on your pic you can see its constantly low which is odd.
