JasonDVamos Posted February 13, 2016 Posted February 13, 2016 I even factory reset the router last night because I had the same problem before and now it happened again...
Asentrix Posted February 13, 2016 Posted February 13, 2016 I even factory reset the router last night because I had the same problem before and now it happened again... Do you have DHCP enabled on the netduma? If yes , check to see if it's also enabled on your 2nd device (modem / router) I'm not 100% certain , but if they're both active , it could cause this problem?
RADDY1993 Posted February 13, 2016 Posted February 13, 2016 I even factory reset the router last night because I had the same problem before and now it happened again... Have you had it connected as wired and wireless ?
toby jugs Posted February 13, 2016 Posted February 13, 2016 ^^^^ this. i have my laptop on the flower twice. it alternates between nameless device and 'my laptop' on opposite sides of the flower dependant on whether i'm wireless or wired. i just checked device manager and my laptop has 2 ip addys as well.
