Sweder13 Posted February 21, 2015 Posted February 21, 2015 I ordered and rcvd my router about a month ago. I installed and used with no issues. My Xbox 1 was direct connected and two laptop were connected via wifi. Everything worked great! Today I noticed that my internet wasn't working (wifi and direct connect to netduma router). I reset both modem and router to no avail. I cannot even locate the wifi "netduma r1" when trying to connect my laptop via wifi. I decided to try to connect hardline via laptop and again no connection. The lights on the router are as follows #2 - bright light, #1 dark light but lit, wifi light - blinking but not bright. Does this tell you anything? I've tried unplugging and using the reset button. Again no connection. Only other info that I feel is needed is I updated the router to the beta version because it software wasn't working on my PC. Is there any other info you need from me? I open to trying to fix this via remotely or returning the product. Just let me know what is needed.PS Just for the record the modem is working as I am directly connected to it now to send this email and use my internet.If need my modem is a Motorola SURFboard Model SB6121Thanks,Shaun PSS - when my router was working I had party issues on Xbox one also. Have those issues been resolved?
Guest Netduma_Iain Posted February 21, 2015 Posted February 21, 2015 Hi Shaun, Party issues require you adding your friend to the allow list. Don't worry I can help you recover your unit, I'm away from machine at the moment but can you schedule a time to help you fix it. Thanks
Sweder13 Posted March 4, 2015 Author Posted March 4, 2015 Hi Shaun, Party issues require you adding your friend to the allow list. Don't worry I can help you recover your unit, I'm away from machine at the moment but can you schedule a time to help you fix it. Thanks
Sweder13 Posted March 4, 2015 Author Posted March 4, 2015 How do I schedule a time to help fix and will I need to be direct connected to modem but have netduma router hooked up to modem? Let me know. Thanks Shaun
Guest Netduma Fraser Posted March 4, 2015 Posted March 4, 2015 How do I schedule a time to help fix and will I need to be direct connected to modem but have netduma router hooked up to modem? Let me know. Thanks Shaun Hey Shaun, you can get a 1 on 1 with Iain tomorrow evening (GMT) you can jump in to chat at the top right of the screen and Iain will hop in and help you Just post in this thread when youre free so Iain knows what time to go into chat Yes that would be the best way to start
