OBS Streaming with Netduma Fix (OBS loosing frames)
Hello everybody.
So yesterday I solved the problem I had with obs when using the netduma r1.
So basically obs was dropping/loosing frames every 30 seconds so my stream lagged every 30 seconds for its viewers. It seems a feature called low latency mode interferes with the netduma all you have to do is go to the options section of obs and go to advanced options. there you will see a network section make sure you have everything unchecked there.
If you have it off already you should not have any problems.
here a picture off how it should be!
obs was set to french language sorry for that I hope those who need this will still find it =)
greetings from switzerland =)
  • 1 month later...
isnt helpful for me at all. I drop 5000 frames in 4 minutes of stream the past few times trying and all is unticked where youve shown!!!! please help!!!!
Guest Netduma_Iain
It could be a bandwidth issue make sure you have anti-flood set to 100% and the define prio has at least 90% allocated to the steaming PC. Also let us know your bandwidth please
Guest Netduma Fraser
60 down 12 up.... I been setting flood at 100% and i always start out dropping frames its been very frustrated!
Have you given the streaming PC 90% on device prioritisation?
