JantsoP Posted December 25, 2014 Posted December 25, 2014 Have low speeds on PC? Then remove avast! anti-virus software. I had this issue and after i changed to eset, no issues. Also check cables + drivers. Check also if someone is torrenting etc on your network. Then check with your Netduma router/ISP box. If they are ok, contact ISPTorrent slow? Disable uTP from settingsSlow wifi? Check if your ISP router wifi is turned off and not using same SSID/password as your new Netduma router. Check with WiFi scanner (android + any laptop/pc with wireless access) what channels are diffrent WiFi hotspots taking. Living in resisental area with alots of wifi connections? Then get 5.0 Ghz AC WiFi router. Dont want to get it? Well you are on your ownHere are some what i have seen in this forum and are quite good answers for your problems.
