Atomic Flange69 Posted October 22, 2016 Posted October 22, 2016 Hi All, Thought you may want to have a look at this video to see what effect the CC settings have on your ping etc. A guy I game with and who is a member on here has done this video which was very interesting and helps see what are the best settings. I found it helpful as it helps put actual numbers against the settings you chose https://www.youtube.com/watch?v=rEOkZiSrEeU
Slipknot31286sic6 Posted October 22, 2016 Posted October 22, 2016 Yes think everyone knows about this. Video should jus be stickied. I did this more in IW beta. Stick to 98/98cc in bo3 60/90cc in IW.
RADDY1993 Posted October 22, 2016 Posted October 22, 2016 Yes think everyone knows about this. Video should jus be stickied. I did this more in IW beta. Stick to 98/98cc in bo3 60/90cc in IW. I run 97 on both as thats best QoS on many other routers, it gives me A+ in DSL Reports. Also remember to enter you speedtest result in bandwidth and always select no when it asks for auto set up.
Slipknot31286sic6 Posted October 22, 2016 Posted October 22, 2016 I noticed even 99/99 I get A+ but not perfect buffer bloat. That varys being on cable but yes always A+ here except 100/100. Dominate in bo3 either way. Happy with R1
