adentutton Posted December 10, 2014 Posted December 10, 2014 Hi guys! Just a question, I am getting a blue screen which says that the Netduma is connected to a router and not a modem? I am on PS3 but I am still getting an Open NAT Type on Advanced Warfare so Im not too concerned, is/will this be an issue? Cheers!
Guest Netduma_Iain Posted December 10, 2014 Posted December 10, 2014 Hi Aden, The BT Home Hub 5 does not have modem mode. So this is the optimum setup for you. The only difference between modem and router is opening NAT. The R1 does as much as possible to open NATs so you don't need an upstream modem. In your scenario it looks like its working perfectly. So there is nothing to worry about.
adentutton Posted December 10, 2014 Author Posted December 10, 2014 Hi Aden' date=' The BT Home Hub 5 does not have modem mode. So this is the optimum setup for you. The only difference between modem and router is opening NAT. The R1 does as much as possible to open NATs so you don't need an upstream modem. In your scenario it looks like its working perfectly. So there is nothing to worry about. [/quote'] Good to hear! Thanks again for your help on Skype yesterday, had a great time playing with amazing connections on AW this evening!
