chris w Posted February 21, 2015 Posted February 21, 2015 well factory reset doesnt seem to be truely factory resetting the router
Guest Netduma_Iain Posted February 21, 2015 Posted February 21, 2015 Hi Chris you need .7 for it to work. Let is know a good time and we will schedule a 1 on 1 session to recover your unit
chris w Posted February 22, 2015 Author Posted February 22, 2015 im available now if that works for u
chris w Posted February 22, 2015 Author Posted February 22, 2015 i have .7 and the interface is abviously diff than .6...but cant do anything with it
Guest Netduma_Iain Posted February 22, 2015 Posted February 22, 2015 Sorry Chris I'm away from machine but so you have a wired connection? If so connect to control panel then goto setting > wifi then change the password of your wifi and reconnect please
chris w Posted February 22, 2015 Author Posted February 22, 2015 i acnt there is no wifi coming out of this thing...ill try that though
chris w Posted February 22, 2015 Author Posted February 22, 2015 wow...changed password and it broadcasts again...strange i would assume it would still broadcast the ssid at least even if it wasnt happy with the password..lolthxs man
