hdmi splitter problems
Taff
i have a "j tech digital hdmi splitter, it has one input and two out. i want to stream my gameplay on twitch but i cant get the splitter to work at all , it has a red power light which comes on but the output hdmi lights wont come on, does anybody use one of these and have any idea whats wrong with it?
i did have it working on my xbox one but it will not work on xbox 360 for some reason.
Make sure HDCP is not "on" in the XB360 settings. Similar to the PS3 and PS4, this prevents the signal from going through a third-party connection and requires a direct connection (console>HDTV) to prevent piracy of the signal.
Also, to stream console game play to a PC to be streamed, I highly recommend you invest in the Elgato HD60 Pro PCI-E internal capture card because using any external USB 2.0 / 3.0 capture device (all brands) is too slow and will result in the gameplay audio and video being out of sync.
I have samples of what real time, perfectly synced game play looks like at 60fps @ 960x540 on my Twitch channel...
twitch.tv/r1_dmg_llc
i use the blackmagic pcie card, ill check and see if i can find the hdcp in the xbox and let you know thankyou.
apparently its my benq monitor hdmi inputs just arent detecting the signal.
it works fine on a my tv hdmi inputs. dvi works but nothing else.
dont understand why it works with my xbox one but not the 360?
there is no off switch for hdcp on the 360 like the playstation, i looked for it.
