Nasser
Netgearxr500 problem
I hav problems in ping and i cant be host the game
ping 100 and 80 an 30 but not god and not the same wth game
Share this post
Link to post
What game and platform are you using? If it is a dedicated server game then it will not be possible to become the host. How are you measuring the ping, in game or by using the Geo-Filter?
Share this post
Link to post
Modern warfare
or fifa
ping - 30..29.. 70..90
In game or geo Its same
If u can tell me how i tak host
thank u
Share this post
Link to post
CoD you won't be able to be host, they use servers. Is the 29/30 ping related to CoD?
FIFA is that the 70-90 ping? If so that's more understandable as it's peer based, how you can get host though is not a guaranteed thing, at least not using the router.
Share this post
Link to post
Yes
server is soo bad and ther is alot of bad host
fifa 50 ping 30
I blok server amazon
i play peer to peer
Share this post
Link to post
Where are you located roughly and where are you getting games? Could you provide a screenshot of the Geo-Filter showing what appears when you're in a game please?
Share this post
Link to post
Look my internt speed 500 m
ping -1
i hav most powerful speed in Saudi Arabia
sorry for that and thank u for ur help
Share this post
Link to post
Thanks for that, I think given your location that is why your ping is that level as the host is unlikely to be in the country but you've actually got a very good ping considering.
Share this post
Link to post
Any suggestions! If u hav tim
yes not bad
The problem i see lag and some tim
aftr i see the kil cam it f..k pig joke
And also the ping not stable in the game
Share this post
Link to post
How many devices are in your home? Do they download/stream a lot when you're playing? There isn't much we can do about distance, though you could try using Ping Assist and see if you can catch any servers under a ping limit.
Share this post
Link to post
I try every thing
if u can advise me  steps or setting  to be host in the game
dedicating or peer to peer till me best setting to be host
i hav setup to be com host
but take time to open lobby
yes som tim  Netflix or apple tv 🤕
Share this post
Link to post
There is no way to force host in the game that I am aware of. I'd recommend you try 70% for both download/upload using Always on Anti-Bufferbloat as that may help when other devices are using the internet.
Share this post
Link to post
I faind wAy to force 🌹
fifa can u help ! Fifa is big problim for me
cod ihav my way
and also thank u for answer 🙏🏻
Share this post
Link to post
Ping Assist is likely what will help the most with FIFA, put your location in the ocean and then set a ping limit, say 50 for example - keep in mind due to distance you may not get many games with that so might need to increase the ping.
Share this post
Link to post
It lik a joke fifa and cod
Ping assist not good i think u need to new update
Thank u for ur answer
last thing i will pay server to play 🙃
If u hav one or u now about thes 😂😂
Share this post
Link to post
I fix my setting
put i will giv u not about what i find after 5 years using netduma and  xr500
Share this post
Link to post
