Ashlin
My Work VPN will not work with the router and I just got sent to work from home
I have a work VPN that I need to use. The settings in the router wouldn't work so I had to plug right into the wall. The family wasn't happy about this as no one else could game or anything. I need to fix by tomorrow. What settings do I need to adjust to make this work for everyone.
Share this post
Link to post
This post would be better in the main forum as plugging into the wall does not mean a lot and others will be able to help you once we know what you are doing.
Share this post
Link to post
Are you using the VPN Client on the router or on your PC? If the router I would recommend doing it on the PC as this is an issue we are aware of. If it's still not working then I would suggest trying to disable QoS completely via the Anti-Bufferbloat menu. If that still doesn't work then set the XR500 to AP mode and then it should definitely work and everyone will still be able to connect to it.
Share this post
Link to post
