Need help
I done the port forwarding and it's worked !! .. quite proud of myself haha .. thanks so much for the help really appreciate it
Fantastic news! So now you know how to port forward, you can follow those steps for any game you have a strict / moderate NAT on and it should sort it out. Ask away if you have any more problems :)
I'm happy as haha .. if I need to port forward for a different game do I delete / disable the numbers for this one ?
For anyone else those port forwarding numbers works for infinite warfare.. modern warfare remastered and black ops 3 .. all open nat in game
No you wouldn't need to disable/delete them. If a different game uses the same ports then great it's already set! If it uses different ones then you can just add those in :)
Great to hear your issue has been resolved, I will now close this thread. Feel free to open another if needed.
Guest
